Tach wiring - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 17th, 01, 05:29 AM Thread Starter
Gary
I have a mini tach with 4 wires. I know what the red and black are for, but there is a green and tan. None of these are for a light as there is no light. Does anyone know which lead goes to the coil. I hate to burn it out. There isn't any brand name on it.
I know it has to be either the green or tan, question is....which one? Thanks!
Gary Dorion is offline
post #2 of 4 (permalink) Old Sep 17th, 01, 05:46 AM
The tan one on my 67 goes to the coil. The car has original guages and tach, so I am not sure if this helps. Not sure what the green would be for.
jwalsh is offline
post #3 of 4 (permalink) Old Sep 17th, 01, 04:23 PM
Cameron
On all the aftermarket tachs that I have hooked up, the green goes to the negative terminal of the coil. The red and black are obvious and the tan goes to a light power source. Are you sure that it has no light?
Cameron is offline
post #4 of 4 (permalink) Old Sep 18th, 01, 06:39 PM
I just hooked up a suntune mini tack in my parts truck 84 s-10 red wire to fuse box on w/key, black to ground duh, green to coil, and blue to fuse box on w/light switch. If you can get the cover off look where the green and tan wires are soldered it probable has a small internal light bulb good luck finding a replacement bulb.
jimbolly is offline
