67 rs headlight to switch diode - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 2nd, 02, 05:37 PM Thread Starter
MJG
Probationer
Michael
Can I change the diode on my 67 headlight to key switch on the brown wire or do I have to get the whole harness with diode installed. What I'm asking is can I buy just the diode and solder it in the line and what kind do I need to try to find and where to get it. Any part numbers handy.Mine was pulled in two by accident. Thank's for any help
MJG is offline
post #2 of 5 (permalink) Old Aug 3rd, 02, 05:55 PM
If you have a Radio Shack or an electronics repair shop nearby you can get one there. What you need is a rectifier diode. It's basically a one-way valve for electricity. Make sure you hook it up in the right direction. Get one that's rated for about 50 volts and 5 amps. Radio Shack sells multi-packs for about $2.50.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #3 of 5 (permalink) Old May 14th, 06, 06:16 PM
Re: 67 rs headlight to switch diode
what does the diode look like? does it look like a small battery with a wire
joe
camro tyler is offline
post #4 of 5 (permalink) Old May 14th, 06, 06:35 PM
a small cylinder with a wire sticking out of each end. It will have a white stripe around one end, that is the positive side.
Radio shack has them, they'll be well marked.
post #5 of 5 (permalink) Old May 15th, 06, 01:28 AM
National sells the RS harness for $34.95. It's cheaper to just get a new diode.
Camaro buds until the end!!!
Camaro Dave is offline
