69 Tach and HEI - Team Camaro Tech
post #1 of 30 (permalink) Old Aug 31st, 03, 12:59 PM Thread Starter
Paul
I have a repop tach and a large body HEI. The tach works fine until I rev it up to about 3000 RPMs and then it jumps around. I have gone through everything that I can think of and nothing fixes it. Any suggestions before I declare the tach junk?
Best of 1.55 - [email protected]
paulm is offline
post #2 of 30 (permalink) Old Aug 31st, 03, 02:13 PM
JohnZ's Avatar
Do you have a tach filter in series with the feed wire from the HEI to the tach? Corvettes with HEI and electronic tachs had an in-line filter, and without one, they do the same thing. [img]graemlins/thumbsup.gif[/img]
JohnZ
CRG
JohnZ is offline
post #3 of 30 (permalink) Old Aug 31st, 03, 03:34 PM Thread Starter
Paul
Really?!?!
No I don't have a filter, do you know where I would get one?
paulm is offline
post #4 of 30 (permalink) Old Aug 31st, 03, 04:56 PM Thread Starter
Paul
I found in my "extra" electronics stuff I have a 47nF capacitor, a 3k resistor and a 10k resistor.....I think that's all there is to the filter!!
[ 09-01-2003, 02:34 PM: Message edited by: paulm ]
paulm is offline
post #5 of 30 (permalink) Old Sep 1st, 03, 10:16 AM Thread Starter
Paul
Do you think that this would work?
From dist....3k resistor to 47nF capacitor, 47nF capacitor to ground, 47nF capacitor to 10k resistor to tach feed.
http://www.stratagaz.com/TachFilter01.JPG
http://www.stratagaz.com/TachFilter02.JPG
paulm is offline
post #6 of 30 (permalink) Old Sep 1st, 03, 10:40 AM Thread Starter
Paul
Angry
Wooooohooooooo!!!!!!!!!!!!!!!!!!! It works!!!!!!!
That tach never worked right until today!!!!
JohnZ, THANK YOU, THANK YOU, THANK YOU!!!!!!!!!
If anyone has problems with their tach and an HEI distributor, one solution may be to try the "tach filter" in my pictures above. I am not much with wiring schematics and such, but with the pics and my description you should be able to figure it out!
You will need:
1) 1 3k resistor
2) 1 10k resistor
3) 1 47nF capacitor
4) 6 inches of 16 awg wire(brown for filter in/out)
6) 6 inches of 16 awg wire(black for ground)
5) 4 butt connectors
6) 1 female spade
7) 1 male spade
8) 1 ring terminal that a 5/16 bolt can fit through
I found this diagram:
paulm is offline
post #7 of 30 (permalink) Old Sep 1st, 03, 11:07 AM
Hey PaulM which is it 3k resistor or 5.6 resistor?
This is so much fun I can't believe it's legal.
69 Camaro- Fastsburn 385 crate, 200-4R
69 Chevelle SS 396 4 Speed
Midlife Cruiser is offline
post #8 of 30 (permalink) Old Sep 1st, 03, 11:33 AM Thread Starter
Paul
Duh.....I used an Orange/Black/Red, which is a 3k!! I tried one with a 5.6k, but it didn't work.....let me fix my info!!
Sorry about that!
paulm is offline
post #9 of 30 (permalink) Old Sep 3rd, 03, 04:03 PM
If you're going to install a bounce filter, making the connections inside the tach housing makes for a clean install. Also, not all tachs will respond to the same combination of resistors. Trial and error will find the proper value. If you don't have a pocket full of resistors, install a 40k adjustable trim potentiometer and adjust until you find the resistance that stabilizes your tach.
Randy S is offline
post #10 of 30 (permalink) Old Sep 3rd, 03, 05:32 PM Thread Starter
Paul
I thought about using a potentiometer, but played with a few different resistors instead. Do you think that the capacitor could need to change as well?
paulm is offline
post #11 of 30 (permalink) Old Sep 4th, 03, 12:33 AM
Cool
No, the cap is fine. All you want to do is to reduce the peak-to-peak voltage of the incoming signal to an usable amount.
The cap levels out the peaks, as in the definition of a "filter," a selective network of resistors, inductors, or capacitors which offers comparatively little opposition to certain frequencies or to direct current, while blocking or attenuating other frequencies.
What you have made is a "T-section" filter.
You're lab score is a 98........Good work !!
post #12 of 30 (permalink) Old Sep 4th, 03, 04:04 AM Thread Starter
Paul
Woohooo a 98!!!
Maybe I'll wire one up with a 40k pot and snap some pictures as an example for people who may encounter this in the future.
paulm is offline
post #13 of 30 (permalink) Old Feb 12th, 04, 11:46 AM
OK...I am encountering it now./ I bought a 50K potentiometer...now what?
Steve W
1968 Camaro Convertible
1966 GTO Convertible
1995 Harley Road King
"You can't always get what you waaant..."
Steve W is offline
post #14 of 30 (permalink) Old Feb 12th, 04, 03:01 PM Thread Starter
Paul
I think that you can wire it the same way that I did mine, just replace the 10k resistor with the 50k pot. You will have to mess with the adjustment until it is right.
One thing that is not apparent in my diagram/pics....Do not hook the wire from the capacitor to a ground, just let it hang free. I tried grounding it at first, but it didn't work.
paulm is offline
post #15 of 30 (permalink) Old Feb 12th, 04, 07:36 PM
So I'd still have to use a capacitor and a 3k resistor? And no ground?
What is a butt connector?
And which end is which...in to the tach or in to the distributor???
When it comes to stuff like this, I'm totally lost....and I could fry one of these components. I just can't do it.
How about you make one for me to plug in and I'll pay you for it? or does SOMEBODY make one???
This sucks...brand new motor and no tach!
Steve W
Steve W is offline
