No brake lights when headlights on! - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 27th, 05, 03:20 PM Thread Starter
I almost hate to post another brake light problem after seeing all the others on the tech line already - but I didn't see an answer to this one. The brake lights on my 68 Camaro work fine in the day, but when the headlights are on, they don't work. Any ideas? Thanks!
CRANE'S68 is offline
post #2 of 5 (permalink) Old Feb 27th, 05, 03:26 PM
CJ
Cris
Did you double check your grounds? Also look at the sockets that the bulbs go into.
Cris
The Rides-
'68 Camaro- 388cid/Tremec TKO/Baer/Hotchkis Susp./Koni shocks/Budnik wheels/Recaro seats
'04 GMC Duramax Crew Cab- Edge Racing Juice/Banks exhaust/Weld Wheels
'73 BMW 2002
'88 BMW M5
CJ is offline
post #3 of 5 (permalink) Old Feb 28th, 05, 03:34 PM
I would agree with a bad ground. The tailight bulbs have two filaments. With a bad ground and the parking lights off the positive feed from the brake light switch will use the other lights in the system as a ground and light up the parking light filaments in the tail lights. When you turn the parking lights on it back feeds through the larger filaments to ground. Step on the brake and both sides become positive and out go the lights.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #4 of 5 (permalink) Old Mar 1st, 05, 04:03 PM Thread Starter
Thanks for the help - it sounds logical. I'll check it out and let you know how it goes. Thanks!
post #5 of 5 (permalink) Old Mar 5th, 05, 12:45 PM Thread Starter
Well, I figured it out and now feel kind of stupid. When I redid the wiring, the wires going into the taillight sockets were corroded, so I took the contacts out of the plastic socket and resoldered them. I must have reversed them when I put them back in. I actually had brake lights when the lights were on (but no taillight) When I applied the brake, it was lighting the taillight filament. Because the brighter brake filament was already on, there was no difference. Oh well, live and learn. Thanks to those that tried to help me!
