1995 Camaro - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 13th, 03, 07:59 AM Thread Starter
Seatbelt light in cluster stays on forever ?
Please help. Thank You
jerry hebert is offline
post #2 of 2 (permalink) Old Jan 14th, 03, 05:23 PM
the seatbelt is a very simple circuit. voltage travels through the clip and only gets the circuit completed when the male end of the seatbelt clip is inserted. the wiring has two paths. the path to illuminate the light has greater resistance than the path through the seatbelt. since electricity takes the path of least resistance, when the seatbelt is inserted, the current will only flow through the belt clip. check for broken prongs inside the female end of the clip. if they are fine, follow the wires to the PCM to find a break in the circuit. this is the only logical thing i could think of.
nate is offline
