lots of electrical problems! - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 20th, 04, 10:40 AM Thread Starter
Just picked up a 73, having some minor electrical issues, looking for help. First off, the dome light stays on no matter what..thinking a headlight switch problem? Next, when you press the brake pedal, the drivers side turn signal comes on, not the brake lights...I am new to Camaro resto, wondering if this has happened to anyone before? Appreciate any help with this, and any 73 Camaro resto tips as well..
Dave in Colorado
dssaa is offline
post #2 of 3 (permalink) Old Feb 20th, 04, 11:18 AM
click's Avatar
Im not sure the 2nd generation had same type system so if you dont find answers here try www.nastyz28.com then tend to have the 2nd gen tricks. good luck and welcome to Team Camaro
click is offline
post #3 of 3 (permalink) Old Feb 20th, 04, 02:20 PM
Steven
A couple of things to check ... One the dome light, you are right that it could be the light switch ... also, remember that a ground is supplied by the door switches ... I would also check the door switches + connectors before pulling headlight switch ... One the brake issue, check that the proper bulbs are installed and properly oriented ... these are easy things to check before getting into more complicated stuff ...
sdtsdt is offline
