Front end wiring harness - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 20th, 05, 02:12 PM Thread Starter
jsouthco68camaro's Avatar
I was troubleshooting a problem with my front turn signals working intermittently and found that my harness is loose where it attaches to the firewall. Is there a strap or? that is supposed to hold it in place or is it just pushed in?
Any suggestions aside from buying a new harness? (Wiring is all good)
1968 Camaro
350 / 4 spd
Then.....
Now....
jsouthco68camaro is offline
post #2 of 4 (permalink) Old Feb 20th, 05, 02:54 PM
Guess
HwyStarJoe's Avatar
There should be a center hexhead screw (or 2?) that pulls the two halves together. Look close. It should tighten up with a small socket. If it's gone, it probably broke off.
I'm not sure if you can get a replacement screw. Try looking at the aftermarket suppliers web sites.
HwyStarJoe is offline
post #3 of 4 (permalink) Old Feb 20th, 05, 03:49 PM
"Tri-Tip"
Gary L's Avatar
If you need a bolt I have one for you. All it takes is one. Send me an email.
Gary L is offline
post #4 of 4 (permalink) Old Feb 20th, 05, 04:59 PM
Paul
Hey Jsouth,
I encountered the same problem and it drove me completely nuts, but in the end I found it. If you end up tightening the harness connection and the problem still occurs, try playing around with the flasher unit that's mounted behind the dash. It's mounted to the vertical support bar almost directly behind the cigarette lighter in your dash. Mine was either sticking or it was not grounding properly and it would cause my blinkers to work intermittently. I reached behind one day when my blinkers weren't working and gave it a half a turn in one direction and I've never had it happen again. Good Luck, Paul
paul1969 is offline
