67 Deluxe dome light wiring - Team Camaro Tech
post #1 of 5 (permalink) Old Apr 26th, 04, 07:30 PM Thread Starter
Jerry Cox
It has been so long sense I removed the harness that I have forgotten how it is run. Any directions or pictures would be greatly appreciated. Thanks Jerry
68 Red with Red & white interior, 383, Offenhauser Crossram, 700R4, Ocala FL
Ocala67RS is offline
post #2 of 5 (permalink) Old Apr 28th, 04, 05:38 AM
Vintage 68's Avatar
It's been many many years since I last worked on my 67 Camaro that had the Custom Interior - but, I think the wiring for the Sail Panel Lamps plugged into the rear harness in the trunk and ran across the package tray bottom area over to the light bases.
This would be under RPO-Z87 in the 1967 AIM or in the Fisher Manual if you have one.
Hope this helps or others with this chime-in soon...
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 5 (permalink) Old Apr 28th, 04, 05:15 PM
That's correct. They should come off the rear harness around the drivers rear wheel well. Usually in the trunk, but could be hiding out in the rear door panel area. Should be orange and white wires. If the back seat is out it's alot easier to get at. Otherwise you get to dive in the trunk. [img]graemlins/clonk.gif[/img]
1967 Mountain Green RS/SS 396/325HP TH400
1967 Barn Fresh 327 PG
67 C10
2006 Lemans Blue Corvette Z51 6Spd
67L35 is offline
post #4 of 5 (permalink) Old Apr 28th, 04, 05:19 PM
Forgot to mention that to get the pass side over it is attached to the underside of the package tray with plastic push clips.
67 C10
67L35 is offline
post #5 of 5 (permalink) Old Apr 28th, 04, 08:40 PM Thread Starter
Jerry Cox
Thanks Guys, I am putting it back together now and was laying out the harness for the dome lights and could not figures out if it ran across the top in front of the rear windows or in the trunk under the package tray. I was looking for the correct size holes for the pushend clip in the harness, but could not find them in the inside of the car. So now I will look under the package tray area for the holes to run the harness. The good thing is there is nothing in the way now for me to find the way the harness should be ran. Thanks again Jerry
