How to check factory millivolt meter - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 14th, 04, 09:55 AM Thread Starter
"Tri-Tip"
Gary L's Avatar
Unhappy
I have my console gages out. How can I check the millivolt meter (amp meter). It registers nothing starting, running etc. HELP!
[ 03-14-2004, 08:28 PM: Message edited by: Gary L ]
Gary L is offline
post #2 of 3 (permalink) Old Mar 14th, 04, 04:26 PM
I had the same problem about a week ago. Here. this is sure to help!
https://www.camaros.net/forum/ultimat...;f=10;t=002820
Good Luck, and let us know how it works out! [img]graemlins/beers.gif[/img]
Steve W
1968 Camaro Convertible
1966 GTO Convertible
1995 Harley Road King
"You can't always get what you waaant..."
Steve W is offline
post #3 of 3 (permalink) Old Mar 14th, 04, 05:27 PM Thread Starter
"Tri-Tip"
Gary L's Avatar
Thanks Steve! Just what I needed to get started. I do not have 12 volts to either side of the gage. So I guess that I have to start at the bulkhead connector. Is it possible the fusible link is fried and I can't see it? Everything else works so it would be weird that only those two pins are not working. I also need to know if there is a separate wire from the junction connector to the gage. From the junction connector there is a 10 red wire to the horn relay and a 14 red to the battery. When I looked earlier today there was a ring connector on the junction box that had no wire attached. Maybe that was the third wire if there is supposed to be one.
Gary L is offline
