volt gauge reading - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 1st, 04, 07:05 PM Thread Starter
I recently purchased a 69 and the voltage gauge reads about 14.5 when the car is running. The problem is it reads 12 when the ignition is off and the key removed. Shouldn't the gauge go to zero with the ignition off? What is wrong? Is it wired wrong or is this the norm. Thanks for any and all help.
YC69camaro is offline
post #2 of 5 (permalink) Old Dec 2nd, 04, 02:56 AM
Voltage gauges aren't stock in a first generation camaro, so a previous owner added it. Gauge should drop to zero with the key off. Sounds like he (or she) wired it directly to the battery or some other always hot power source instead of a switched source.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 5 (permalink) Old Dec 2nd, 04, 06:18 AM
Normally (for cars that have volt guages), a voltage guage is wired to IGN power. This way you can see the cranking voltage of the electrical system. If ACC power is used, the voltage guage will go to zero during crank.
dnult is offline
post #4 of 5 (permalink) Old Dec 2nd, 04, 10:15 AM
I wired mine direct to the cigarette lighter wire, which is hot all the time. There is nothing wrong with having the voltmeter read all the time.
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #5 of 5 (permalink) Old Dec 2nd, 04, 08:33 PM Thread Starter
Thanks for the replies. That lets me know what my options are. Thanks again!
