RS doors - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 28th, 02, 06:32 PM Thread Starter
Is there a cheaper and more simple way of operating my headlight doors (electrical) than buying all those expensive relays and door stops?
thanks
michwalt15 is offline
post #2 of 2 (permalink) Old Nov 29th, 02, 07:58 AM
are you missing those parts, or are you assuming you need to replace them because they don't work. if they are there, i would advise buying a wiring schematic and checking everthing, including the motors. this is what i did, and i was able to fix mine for about 50.00, using all the original motors, door stops. justhad some melted wires and bad circuit breaker. also, the motors have a plastic housing that encases reduction gears, they can strip easily on the inside, but the motor is still good. now my hideaways work and all parts are original.
67 RS marina blue
SUPER T10 4 SPD,9" ford 4.10 gears. 377,13:1 comp., srp forged pistons,comp xs282s,speed demon 750, roller rockers,sportsman II's
91 formula 350 firebird (wifes car)
01 siverado 2500HD
67FREAK is offline
