Quick Alt Amps ?? - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 21st, 05, 06:14 AM Thread Starter
Dean
Probably a dumb one tho..
When a company advertises a 140 amp alt, do they mean 140 max at a certain RPM and something like 60 amp at idle? [img]graemlins/clonk.gif[/img]
Dean
'69 355-3.73 Moser-Truetrac-TKO-600-Hotchkis-DSE-QA1 coilovers-Baer brakes-17"Budnik's-Speedtech control arms
SICKT9 is offline
post #2 of 4 (permalink) Old Jan 21st, 05, 06:44 AM
Majority of the time, yes.
post #3 of 4 (permalink) Old Jan 21st, 05, 10:12 AM
No such thing as a dumb question. A 140A alternator should put out 140A maximum at and above a certain alternator armature speed (depending on pulley sizes the crank RPM may not be the same as the alternator's RPM). Below that speed it will put out less. How much less depends on the manufacturer. The 140A rating could have been measured at 0 degrees or at a temperature of like 200 degree's. Temperature effects the output also.
An alternator even though rated at 140A output maximum will be allowed to have that amount of output or less depending on the signal it is getting from the voltage regulator. If the car is running down the road the alternator might only be putting out 60A but if the headlights are turned on the output may be increased to 70A to compensate for the increased current demands. If the demands of an electrical system are more than 140A then the remainder is coming off of the battery (if you have a 200A total electrical system load hooked up in a system with an alternator putting out 140A maximum then you will be drawing 60A off of the battery) and eventually, since the battery is does not create electricity, the voltage will go down until the battery has nothing left to give and now the electrical devices are given reduced voltage and things like headlights will become dimmer and electric motors will spin slower as the alternator is trying to supply it all.
SOA-Nova is online now
post #4 of 4 (permalink) Old Jan 21st, 05, 03:56 PM
That's one of the reasons the CS130 alternators are so popular. They put out enough charge at idle to keep it all going. The old stock alternators barely work at idle.
dnult is offline
