No Parking Lights What the..... - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 15th, 03, 03:20 AM Thread Starter
Hi, I freaking out with this problem I'm having with the parking lights. Uh there are none. The only lights that work are the signal, head lights and brakes. There are no dash lights or corner/parking lights. The test light doesn't work from the "lamps" outlet fuse in the fuse box. The switch works, it tested ok HELP
1968 SS Convertible
Green Hornet is offline
post #2 of 2 (permalink) Old Jan 15th, 03, 07:30 AM
Here's a description of the headlight switch wiring. https://www.camaros.net/forum/Forum10/HTML/001948.html
Your problem may be a blown tail light fuse or dirty fuse clips on that fuse. That's where the orange wire comes from. Suspect that there is no power on the orange wire.
John_Muha is offline
