Help, electrical problem - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 9th, 05, 08:23 AM Thread Starter
I am working on a 69 RS Convt, Car is running great, however I have found an electrical problem. The (-) is hot and the (+) is grounded. What would cause this? The dash lights come on when I hit the brakes, am I missing a ground somewhere. What is make the car HOT.
mk69camaro is offline
post #2 of 5 (permalink) Old Feb 9th, 05, 11:15 AM
It sounds like the grounds are a good place to start. The positive will feed through the bulb filaments to a metal component that isn't grounded making it positive. Try running a temporary 10 or 12 gauge wire from the negative battery post to a good clean screw on the body somewhere and see what happens.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 5 (permalink) Old Feb 10th, 05, 06:22 AM
The - is hot and the + is cold compared to what? What are you using to measure voltage, and how and where are you connecting it? The - terminal on the battery would be connected directly to the block, so if you put your neg meter lead on the block or body sheet metal, everything would be either 0 or positive in relation to that.
post #4 of 5 (permalink) Old Feb 11th, 05, 01:36 PM
Battery hooked up backwards perhaps?
dnult is offline
post #5 of 5 (permalink) Old Feb 12th, 05, 06:47 PM
If the battery is hooked up backwards, what will happen is the wire will burn your fingers and make lots of sparks.
dnult is offline
