68 Camaro Brake light - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 27th, 04, 06:01 PM Thread Starter
Yesterday for no reason I can find my pass side brake light stoped working. I tested the wire and it is not getting power, but the other side is. Any one have any suggestions?
Dustin
kiknss is offline
post #2 of 5 (permalink) Old Mar 28th, 04, 01:55 AM
Paul
PDQUICK's Avatar
On our cars, the directional and brake light share the same bulb filament. Basically, the turn signal switch disconects the brake light wiring from one bulb when the turn signal is on. I suspect that you have a turn signal switch problem.
Paul D.
PDQUICK is offline
post #3 of 5 (permalink) Old Mar 28th, 04, 04:09 AM
click's Avatar
Also pull the plug apart thats up under the drivers side wheel hump area in the trunk and check the lines for power at the connector there. If you have power there, its somewhere between the connector and the socket. If no power there, then next leg of the wires connect near the emergency brake pedal area, another connector there.
Before you tear into the switch, check power from those connectors. Then switch is probably the culprit.
click is offline
post #4 of 5 (permalink) Old Mar 28th, 04, 06:40 AM
There is another connector under the dash near the emergency brake pedal that feeds power to the rear. You can check there for voltages as well.
dnult is offline
post #5 of 5 (permalink) Old Mar 28th, 04, 06:54 AM
click's Avatar
Dave I said that up above
at least he knows its an important area to look.
click is offline
