Head Light Switch Removal for a 68 - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 6th, 03, 04:24 AM Thread Starter
Any tips on how to remove the complete headlight switch on a 68 convertible?
1968 SS Convertible 350 4 speed
Green Hornet is offline
post #2 of 7 (permalink) Old Feb 6th, 03, 12:03 PM
Try this link, that topic has been discussed in detail here.
https://www.camaros.net/forum/Forum5/HTML/002496.html
Kens68 is offline
post #3 of 7 (permalink) Old Feb 17th, 03, 08:47 AM Thread Starter
This is a great thread, but it focuses on the light switch shaft not the actual switch I've got the shaft out but I cannot remove the rest of the switch from the back of the dash. Thanks.
post #4 of 7 (permalink) Old Feb 17th, 03, 08:55 AM
Green,
There is a special tool made for the nut on the front of the switch, but it can be removed with a pair of robogrips , make sure you use the non-marking pads on them. I have also used a flat blade screw driver in the slots to turn it as well. Hope this is what you were looking for and it helps out.
Kevin<P>68 Camaro SS - 383, Edlebrock Performer RPM, Trick Flow 23 degree heads, edlebrock 750cfm carb, dynomax headers, Tremec TKO, 3.73 Posi
kdorsett is offline
post #5 of 7 (permalink) Old Feb 18th, 03, 04:16 AM Thread Starter
Thanks for the tip, I'll give it a try tonight. I thought it may have been that but I was afraid to break anything. Thanks for your help.
post #6 of 7 (permalink) Old Feb 18th, 03, 09:01 AM Thread Starter
Hi Kevin, got the light switch out thanks for your help.
post #7 of 7 (permalink) Old Feb 18th, 03, 09:14 AM
[img]graemlins/thumbsup.gif[/img] No problem, that's what we are all here for.
kdorsett is offline
