CS series vs SI series? - Team Camaro Tech
post #1 of 2 (permalink) Old Feb 22nd, 04, 04:33 PM Thread Starter
MStennes's Avatar
Are the CS series alternators better than the 130 watt SI series? If so why? What has to be done to convert from my 100 amp SI to a 130 CS or should I just up grade to a 130 SI?
Thanks,
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc,
Welfare is completely against freedom and the principles of american life, paying people not to work by stealing from the people who do is insanity.
MStennes is offline
post #2 of 2 (permalink) Old Feb 22nd, 04, 06:23 PM
Of the things I've noted on the CS130 I just bought today - The CS-130 is smaller that the SI. Both the rear and the front bearings are sealed rollers. The SI alternators that I have worked on have a roller bearing in the front and a bushing in the rear. The CS-130 has an extra fan internally attached to the rotor in the rear section to provide more cooling air flow over the regulator. So it should provide more power in a smaller container, run cooler and last a long long time.
dnult is offline
