69 wiring problem - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 18th, 03, 03:37 PM Thread Starter
Is there any plasce on the web where Ican get a wiring diagram for a 69?
My 69 died a few weeks ago and totally drained the battery while I was driving it. I thought it was the regulator so I changed it and charged up the battery. It is still dead so I removed the red wire that from the postive battery cable and a one lug terminal block located behind the battery (towards the passenger side of the car). With this wire removed from the battery cable, I measure about 24 Ohms between it and ground, so I suspect that something connected to this circuit is drained the battery...
Any ideas of how to trouble shoot this or anyone with a wiring diagram?
japper
japper is offline
post #2 of 5 (permalink) Old Sep 18th, 03, 05:33 PM
click's Avatar
japper the Camaro Factory Assembly Manual has a complete wiring diagram and its one of the most usefull tools you should have for your camaro. They are offered thru our site sponsor Ground Up as well as on ebay and other resto places. good luck, chasing elec. is never easy but it is fixable.
[img]graemlins/thumbsup.gif[/img]
click is offline
post #3 of 5 (permalink) Old Sep 18th, 03, 05:57 PM
If nothing else is on such as a clock or an aftermarket stereo, I'd have the alternator checked out.
John_Muha is offline
post #4 of 5 (permalink) Old Sep 18th, 03, 06:47 PM
John's probably onto something. Disconnect the power lead from the alternator and see if you still measure 24 ohms. Diodes in the alternator can short causing a drain on the battery.
-dnult
dnult is offline
post #5 of 5 (permalink) Old Sep 19th, 03, 04:48 AM
john
camaro_z28_1969's Avatar
I've got the '69 wiring diagrams in an album on webshots - look in my signature...
good luck, John
japper
1969 Z/28 - owned since 1971 - garaged since 1985 - in process of restoring it
camaro_z28_1969 is offline
