68 or 69 AC relay switch - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 10th, 04, 06:48 AM Thread Starter
I'm going to replace my relay switch for ac and in looking at catalogs, I see many 68 switches which appear to be the same as the one on my 69. I can't seem to find any for a 69 that show a picture. Are they the same switch or are there differences between the two that you can't see?
Any help is always appreciated..
Dave, 69 Coupe, 383, Q-jet, Thorley headers, 350 turbo, P.S., P.B. console gauges, Tilt wheel, Black with green pearl paint, Black and White Houndstooth interior.
Black69 is offline
post #2 of 7 (permalink) Old Aug 10th, 04, 07:43 AM
Could this be what your looking for ?
Ricks First Gen Part # RC 202 1969 A/C Relay top of the box
Rsmith1969 is offline
post #3 of 7 (permalink) Old Aug 10th, 04, 08:14 AM Thread Starter
Angry
That is probably the part I need. It does appear to be different from the one that is on the car now, as far as the prongs go. It also appears that I have a relay from a 68 on there now. Does anyone know if the are different other than cosmetically.
Black69 is offline
post #4 of 7 (permalink) Old Aug 10th, 04, 11:42 AM
click's Avatar
This should be the relay you want. Some catalogs dont agree and give you the wrong one and then it doesnt work right, I went thru 3 before insisting on the right tabs . Hope this helps.
click is offline
post #5 of 7 (permalink) Old Aug 10th, 04, 12:28 PM Thread Starter
Red face
The relay I took off is that same as the one you show in appearance. However the tab for the ground is in the number 4 postition rather than the 5 position. I don't know if this is correct as this relay matches the ones for 67-68 in the catalogs and I was told that some go from 68-72. Any ideas??? I don't know if this relay was original to the car.
Black69 is offline
post #6 of 7 (permalink) Old Aug 10th, 04, 04:52 PM
click's Avatar
I tried the relay with ground in #4 position and the fan didnt work on high speed. When I put this one in place (pic), it fired right up and works on all 4 speeds nicely. print out this pic, take it to your napa or auto parts store and they can get you their catalog that shows the relay and its tabs. Then order the one that matches this one. you should be good to go then.
click is offline
post #7 of 7 (permalink) Old Aug 15th, 04, 12:32 PM Thread Starter
Angry
Thanks for everyone's help. I found that many resto catalogs sell the relay that actually is for 67-68 cars to include 69-70. This is for the high speed. If you use the wrong one you will have no high speed. I also found that NAPA has the correct one for 69 which is different from the 67-68. Echlin AR108 is the correct part number, $19.69 + tax.
Black69 is offline
