No start problem - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 8th, 04, 04:50 PM Thread Starter
Lorne
After reinstalling the engine I cant get the starter to turnover from the ignition switch. I can get it to turnover from the starter itself. I only installed the one wire harness at the firewall that contains the wiring that goes to the starter etc and not the other harness that goes to alternator etc as I am going to install a one wire alternator and eliminate the voltage regulator etc. Do I have an incomplete circuit without the other harness hooked up? If so can I complete the circuit by wiring it up differently for now? Im just testing the engine not operating the vehicle so fancy is not required. Help please!
MickyT is offline
post #2 of 3 (permalink) Old Mar 8th, 04, 05:02 PM
Rick
Do you have the nuetral safety switch connected? Car will not turn over if is is disconnected.
rcatalano is offline
post #3 of 3 (permalink) Old Mar 8th, 04, 05:10 PM Thread Starter
Lorne
Yes I jumped the two purple wires as I have the console out right now. Still not sure how a complete circuit is made, if both harnesses are needed. I have no power at the HEI and elsewhere.
MickyT is offline
