Wireing daigram for Zirgo electric fan - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 16th, 04, 09:21 AM Thread Starter
I just bought the 16' Zirgo electric fan and man is it nice. It came with the adjustable thermostat switch. The only problme is I don't know how to wire it up. I have a wire harness for it with the relay and the fuse but It didn't come with a wire diagram. Do any of you guys know how to wire it? THere is Red and black wire that i will assume are the Hot and the ground. Then there is an orange with a fuse in it, there is also a green with a fuseable link, then there is a yellow and a brown that goes who know's where? All of there wires run to a 40amp relay. THe yellow is not plugged into the relay it is hanging loose but it has been bundeled with the rest of the wires. Any Ideas?
(Admin sorry for the double post)
69 Camaro RS, 383ci,10.5-1 AFR 195's ported, Comp 286HR, 4340 forged Crank & Rods, JE Pistons, RPM Airgap, Holley 750 HP carb, 350 turbo w/ shift kit, 3000 Coan, Be cool, caltracs,12bolt 355 eaton posi..Best E.T. 12.22 @ 112
69CamaroRacer is offline
post #2 of 3 (permalink) Old Dec 16th, 04, 11:17 AM
I recently wired up a Spal 16" electric fan. Maybe this will help give you a general idea of the wiring. The fan had a black and red wire. Black goes to ground, red connects to the red wire on the relay. Other wires from the relay include a yellow wire with a fuse that connects to battery power, an orange wire that connects to ignition power, and a gray wire that connects to the temperature switch. Hopefully someone with the Zirgo fan will respond. Have you tried contacting the manufacturer?
Woody68 is offline
post #3 of 3 (permalink) Old May 2nd, 05, 11:13 AM
kris
Send a message via AIM to kristofer
Re: Wireing daigram for Zirgo electric fan
i am beginning to wiring spal dual fan setup........where did you locate your relay? do you have pics?
1968 CamaroCorvette Bronze 396 TKO-
1978 Camaro Type LT 99% original
2005 FLSTFI 15th anniversary Fatboy Softail.
kristofer is offline
