Help! no low beams - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 19th, 04, 06:57 PM Thread Starter
just lost my low beams on my '68! high beams still work along with all other lights. fuses all look ok. What's wrong?
68dailydriver is offline
post #2 of 7 (permalink) Old Feb 19th, 04, 08:41 PM
Well...maybe the bulbs burnt out! Check them carefully. OK, that was the real obvious answer.
Another option, if you're sure the bulbs are OK, is to check the dimmer switch itself and the wiring. I had a similar problem in BOTH my Camaro and GTO.
Also, check your grounds for the headlights and parking (turn signal) lights, especially if they share a common ground.
It might be other stuff, and I'm sure the guys here will add their .02 (two cents...hmmm, what's that in Canadian?)
Good luck, eh.
Steve W
1968 Camaro Convertible
1966 GTO Convertible
1995 Harley Road King
"You can't always get what you waaant..."
Steve W is offline
post #3 of 7 (permalink) Old Feb 20th, 04, 03:33 AM
click's Avatar
I vote with Steve, dimmer switch, gets junk in the contacts, plug pulls loose, wire pinched, just pull that switch out, clean up the contacts and give her a go. [img]graemlins/thumbsup.gif[/img]
If that doesnt work, for low beam use those old magnetic flashlights clamped to the fender [img]graemlins/clonk.gif[/img]
click is offline
post #4 of 7 (permalink) Old Feb 20th, 04, 07:05 AM
I had that same problem once..and these guys hit the nail right on the head! I changed out my dimmer switch and..."presto"...No more trouble! [img]graemlins/hurray.gif[/img]
Now as far as everything else was concerned....
When you buy an American car, you provide work for a man and his family for three months. -Jay Leno
garfield is offline
post #5 of 7 (permalink) Old Feb 20th, 04, 09:10 AM
I had this happen in my 78. It may be your high beam switch as well. Unfortunatley I only found out about that switch after I changed every other one. Good luck.
Green Hornet is offline
post #6 of 7 (permalink) Old Feb 20th, 04, 10:44 AM
Another vote for the dimmer switch. Had it happen in my 67.
sudo1a67ss350 is offline
post #7 of 7 (permalink) Old Feb 21st, 04, 02:05 PM
Well......?
Steve W
Steve W is offline
