Install factory tach in place of fuel gage - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 30th, 05, 03:48 PM Thread Starter
Two questions about installing new factory tach in place of old fuel gage. 1) Does the back of the instrument panel have to have a major triangular hole cut into it? I guess then the three screws on outside edge hold the gage in place. 2) I upgraded my ignition to the crane electronic system including coil. Can I expect any problems with it working properly? Which side of the coil does it get wired to by the way?
69rag327 is offline
post #2 of 8 (permalink) Old Jan 31st, 05, 07:36 AM
Just did that. Here's the link: https://www.camaros.net/forum/ultimat...c/10/3476.html
As I'n not using factory guages in the console, I did not buy the repro tach curcuit board or guage conversion harness. I modified the existing circuit board, and will have to repurpose 1 wire in the dash harness.
The tach bolts right in in place of the fuel guage, but the circuit board needs to be reworked / clearanced, and a few wiring changes made.
I think / hope the new repro tach will work fine with electronic ignition.
The tach wires to the NEGATIVE side of the coil.
post #3 of 8 (permalink) Old Jan 31st, 05, 03:47 PM Thread Starter
Thanks for the reply Jim. Looks like we are doing the same thing but to different years. I did not think I had to do much but butcher the back of the old fuel cavity. The factory tach has a triangular formation on the back so it can't fit in the cavity. I wonder if that mean there was a separate carrier for tach cars and fuel gage cars?
69rag327 is offline
post #4 of 8 (permalink) Old Jan 31st, 05, 04:28 PM
ZZ_430's Avatar
If you'll look closely at the back of your carrier, you'll see a "triangle" line that you can use as a guide for cutting it out.
[ 01-31-2005, 06:40 PM: Message edited by: ZZ430DropTop67RS ]
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #5 of 8 (permalink) Old Jan 31st, 05, 05:44 PM
I replaced my dash fuel gauge with a tach and yes you have to cut out a different hole. I thought that the tach I ordered came with a template and I believe that the mounting holes are the same. It's been a while. I didn't get a new dash bezel so I know that I had to cut clearance for the tach.
Mine is a '69 if that's what you're working on since you're "69rag327".
Tokala is offline
post #6 of 8 (permalink) Old Jan 31st, 05, 05:59 PM
lol, and I thought EVERYONE has a '68... [img]graemlins/clonk.gif[/img]
post #7 of 8 (permalink) Old Jan 31st, 05, 06:00 PM
Brad
HI, How do you guys like using a factory tach? I have one bit its broken. I cant figure what would be better, buying an aftermarket "Autometer" or sticking with stock repop? Do anyone know the differences, plus negatives of the 2 tachs? Any input would be great.
Most recent 01/01/10
spideynut is offline
post #8 of 8 (permalink) Old Jan 31st, 05, 06:01 PM
lol... I know "nothing" about 69's, they're different!
