Generator Light? - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 14th, 01, 06:37 PM Thread Starter
The generator light on my 69 Camaro is staying on when the car is running. It seems to fad some, but still is on. What should I check? The battery seems to be staying charged, so I am assuming that the alt. is working correctly.
eagle 670 is offline
post #2 of 5 (permalink) Old Aug 14th, 01, 07:16 PM
This can steam from many things. First of all check your ground for the center dash (center screw?). It's very common to be faulty. Mine was actually gone so I ran a wire from the dash to the center bezel.
Second, my iginition was ran wrong and it was causing a similar effect.
Third, check the voltage regulator / horn relay. Both of mine were bad and this may cause the same effect.
Last (but certainly not least) there is a brown resistance wire from the voltage regulator and if it was tapped / spliced into then it would cause this effect since the resistance would change.
Let me know how it goes, I like keeping track of these problems (gathering info a database) and good luck!
Cars:
68 SS Camaro
73 Camaro -Daily Driver
Website:
http://68.dhs.org
ohayden is offline
post #3 of 5 (permalink) Old Aug 14th, 01, 07:41 PM Thread Starter
Where exactly is the ground wire on the dash? Does it connect to the steering column? It seems to me that there was a wire connected to the underside of the column, but it was broke off. If I hook this back up, where does the other end need to be connected to? Can you give me some detail on this please?
Thanks!
post #4 of 5 (permalink) Old Aug 15th, 01, 05:53 AM
Talking
There isn't a wire (normally). It is actually the top / center screw on the center dash bezel that grounds it to the dash.
What I did was ran a wire from the dash to back side of the center dash bezel. As for a wire on the steering column.... hmmm... there should be a group of wires that run down the column and connect under the dash. The connector is in the shape of a quarter moon.
For testing purposes ground a wire from the body or dash to the bezel.
Cars:
68 SS Camaro
Website:
http://68.dhs.org
ohayden is offline
post #5 of 5 (permalink) Old Aug 15th, 01, 04:23 PM
Had a similiar problem....Turned out to be a bad ground on the voltage regulator..
The voltage regulator grounds using its mounting screws..good luck
Retored 76 LE Trans Am 455 4 speed..# matching FOR Sale or Trade for a 68 or 69 big block camaro in good shape
Restored 68 Camaro R/S 327 4 speed
Badcaiman is offline
