temperature gauge - Team Camaro Tech
post #1 of 20 (permalink) Old Dec 19th, 00, 08:35 AM Thread Starter
I'm working on my 69 console gauges, they weren't hooked up. Does anyone have have the prints for the console area. My Chassis book doesn't cover this. Also, what terminals on the temp gauge get hooked up and where does the resistor sit on the four studs. thanks scott
scott lauters is offline
post #2 of 20 (permalink) Old Dec 19th, 00, 10:14 AM
AL
I took these pics so I would know how to put my gauges back together.
http://members.aol.com/machman631/gauge1.jpg http://members.aol.com/machman631/gauge2.jpg
Hope this helps....let me know if you need more info. What prints are you talking about?
There is a lot of good info in the assembly manual. There is also alot of info on this site reprinted from a magazine...in sure somebody else can link it for you.
AL.
302XRAM is offline
post #3 of 20 (permalink) Old Dec 20th, 00, 05:10 AM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by scott lauters:
I'm working on my 69 console gauges, they weren't hooked up. Does anyone have have the prints for the console area. My Chassis book doesn't cover this. Also, what terminals on the temp gauge get hooked up and where does the resistor sit on the four studs. thanks scott<HR></BLOCKQUOTE>thanks for the picture it helped. someone cut the ends off and put crimp on ends on instead. my gauge still doesn't work now I don't know if it's the gauge or the sending unit
post #4 of 20 (permalink) Old Dec 20th, 00, 04:52 PM
When I first installed my gages, the temp gage didn't work. Turned out I had the two leads crossed, so as it got hot. The gage read colder. because it was pegged. It didn't move. Maybe it's that simple.
TTFN
Mat
Mat Klemp is offline
post #5 of 20 (permalink) Old Dec 21st, 00, 11:17 AM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by Mat Klemp:
TTFN
Mat
<HR></BLOCKQUOTE>
thanks mat! question i've got is the pink or red(which ever)hot, 12 volts and the green goes to the sending unit. merry christmas to you all!!!!!
post #6 of 20 (permalink) Old Dec 21st, 00, 12:09 PM
AL
scott...do you need a pic of the back of the gauges with the wires on it?
AL.
302XRAM is offline
post #7 of 20 (permalink) Old Dec 22nd, 00, 02:22 AM Thread Starter
that would be great if not a big bother
thanks again, AL
scott
[This message has been edited by scott lauters (edited 12-22-2000).]
post #8 of 20 (permalink) Old Dec 22nd, 00, 01:03 PM
AL
Here ya go Scott....hope this helps.
Al. http://members.aol.com/machman631/gaugewire2.jpg
[This message has been edited by 302XRAM (edited 12-22-2000).]
302XRAM is offline
post #9 of 20 (permalink) Old Dec 22nd, 00, 05:23 PM
AL
Sorry Scott I had the wrong pic in the above post....its fixed now.
AL.
302XRAM is offline
post #10 of 20 (permalink) Old Dec 23rd, 00, 06:54 AM
Scott I hope the pictures helped I don't know what wire is what. I used test light to find the hot wire.
TTFN
Mat
post #11 of 20 (permalink) Old Dec 25th, 00, 05:25 AM Thread Starter
thanks alot Al and Mat!!!!!!!!!you guys have a merry christmas!!!!and a safe one!
post #12 of 20 (permalink) Old Dec 26th, 00, 03:52 AM Thread Starter
Al and Mat,
i got the wiring done on my temp.gauge, thanks for the photo. i was working on my car yesterday trying to trace some more wiring. i still don't know if the pink wire is hot(12v.). it comes from a terminal off the bottom of my steering column just above the floor board. scott
post #13 of 20 (permalink) Old Dec 29th, 00, 02:25 AM Thread Starter
Al, thanks for everything! i got the gauges working last night. one more question though. in the last picture you sent me, what is the black round object with the three wires and holds a light bulb? i don't know what makes it work..... thanks, scott
post #14 of 20 (permalink) Old Dec 29th, 00, 04:34 AM
That's the low fuel light relay (for lack of a better term). It is wired across the fuel gauge terminals and turns on the FUEL light in the left dash pod when you get down somewhere around 2 gallons of gas in the tank. It doesn't have a light in it, the original ones have a light socket base attached to the end that is used to attach it to the metal base of the gauge cluster. Reproduction ones are available but don't have the light socket on them.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #15 of 20 (permalink) Old Dec 29th, 00, 05:58 AM Thread Starter
hey thanks Mark!!! mine this there and must work too,cause the low fuel light does come on. i just didn't know what it did. have a good new year!!
