Leaving key in on position - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 24th, 04, 04:57 AM Thread Starter
Years ago, when all the cars had were points in the ignition system, my Dad told me that leaving the key in the "on" position would burn the points. Is this a myth or not. Also, does leaving it in the "on" position with electronic ignition harm anything?
67 Coupe<br /></font><ul type="square"><li><font size="2" face="Verdana, Arial">ZZ4</font></li><li><font size="2" face="Verdana, Arial">12 Bolt Posi</font></li><li><font size="2" face="Verdana, Arial">4-Spd</font></li></ul><font size="2" face="Verdana, Arial">
67killerb is offline
post #2 of 4 (permalink) Old Mar 24th, 04, 05:00 AM
killer,
this is true i left the key in the on position in my 68 and burned the module up.
Nick
68 camaro, 350, comp cams xe262, hooker super comp headers, torque thrust II's, its a work in progress
NDubs68 is offline
post #3 of 4 (permalink) Old Mar 24th, 04, 10:52 AM
JohnZ's Avatar
That's why the "accessory" position is there - it disconnects the ignition circuit. [img]smile.gif[/img]
JohnZ
CRG
JohnZ is offline
post #4 of 4 (permalink) Old Mar 24th, 04, 12:03 PM
Definately true with breaker points. The points and the coil will suffer. As for solid state ignitions, I'm not sure it is an issue. I image they only ground the coil for a short duration when pulses are recieved from the pickup. Application specific behavior I would presume.
dnult is offline
