67 Factory In-Dash Tach - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 13th, 02, 08:35 AM Thread Starter
Need some help guys. Keep in mind that I am by no means an electrical expert. I just finished removing the in-dash factory fuel and installed a repo factory tach. I also put in a new repo circuit board. All the lights work, however the tach doesn't. It appears to have power coming to it because when I turn the key on the needle will jump a little.
I need to know if there are any external wiring (independent of the circuit board) I need to run to make this thing work. I noticed that the tach as two termials coming off the back. Should these be used? I am running an MSD 6AL, MSD dist and coil.
Thanks,
Gary
Gary
1967 Camaro SS/RS 396-375 4sp.
http://community.webshots.com/user/amike95
Gseay is offline
post #2 of 3 (permalink) Old Oct 13th, 02, 03:30 PM
first let me say SHARP CAR !
you will need the wire's from your distributor hooked into the tach , my car came with the factory tach and it has a lead for it , you can hook it up yourself or you could get a wire kit made just for it ,
69 camaro traded for 67 camaro traded back for 69 now back with a 67 rs WILL IT NEVER END ,,,,,,,,,,,,,,
I HOPE NOT .
ADVENTURE'S IN RUST REPAIR
mebe_epp is offline
post #3 of 3 (permalink) Old Oct 14th, 02, 06:21 AM
If you want my tach / gauge conversion schematics, diagrams and technical descriptions, let me know and Iíll email them to you. There are a few large files, about three floppies fullÖ
Geezer
[This message has been edited by Geezer (edited 10-14-2002).]
Geezer is offline
