67 Gauge Cluster - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 7th, 05, 09:17 AM Thread Starter
When I turn the dimmer switch for the dash lights to get brighter the gas gauge goes to empty. Any idea why this would happen? Do you think the circuit board on the back needs to be changed?
broom34 is offline
post #2 of 4 (permalink) Old Mar 7th, 05, 11:29 AM
wow, that's pretty wierd... best guess, bad ground on the dash carrier, the fuel guage is grounding through the light switch ( when it's set to dim)
There's a metal strap the runs from one of the instrument carrier mounting screws, up to the high beam indicator, then to the center mounting screw behind the dash carrier
post #3 of 4 (permalink) Old Mar 8th, 05, 05:51 AM
My guess too would be any grounds.. I had wierd happenings when I neglected to replace the center mounting screw right above the steering wheel. It is a ground for the instrument panel, sometimes it would work when it wanted to , other times it did not. Drove me crazy.. replaced the screw and all was fine... Good luck
Long Gone: 1984 Z28, 1989 RS
Current : 1967 Coupe w/350, 2010 2SS
My Photobucket >>
dragon0123 is offline
post #4 of 4 (permalink) Old Mar 30th, 05, 09:04 AM Thread Starter
Re: 67 Gauge Cluster
Followed your advice and ran a ground wire from the back of the instrument cluster to the firewall. This solved the problem on the gas gauge. But, now I have an issue with the turn signals. They are not working. Any ideas?
broom34 is offline
