68 camaro floor dimmer switch? - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 17th, 03, 07:29 AM Thread Starter
I am almost made it through inspection, but my floor dimmer switch for the headlights doesn't work.
I live 2 miles from the inspection station and got pulled over for no inspection, registration or plates. Funny, I haven't seen a cop around here in years [img]smile.gif[/img] He let me go, so what can I say. It is really torn up and not even bolted to the floor. If you wiggle it it will switch between high/lo, but the switch itself looks corroded. Is this really a switch that clicks up and down when you stomp it? If it is a switch it is totally frozen/corroded and would need replacing. Does anyone know a source fro the dimmer or a part number. I can't seem to find a place or if I have, I'm not sure the part is right because it doesn't show an image. Thanks!
rphtx is offline
post #2 of 5 (permalink) Old Jun 17th, 03, 07:49 AM
rphtx:
It is an actual switch. Replacement is pretty straight forward. Payattention to where each wire goes when you take the old one out. Digital pictures work great-just in case. I would think any after market Camaro restoration would have one.
D. Schribert
'68 Camaro
Dan
'68 Camaro Convertible
dschribs is offline
post #3 of 5 (permalink) Old Jun 17th, 03, 09:05 AM
I bought one for my 67 at Autozone, I think it was about 5 bucks, been working for over a year.
Calebs67rs is offline
post #4 of 5 (permalink) Old Jun 17th, 03, 10:07 PM
Sean
i also bought mine at schucks (checker, kragen, whatever), it's still going strong after three years. there actually should be a plug that plugs right into the switch, at least this is how mine is. i almost bet that the floor dimmer switch in all older chevys is the exact same part. should be easy to find, real easy to replace. there are two screws that hold it to the floor, one of them may be hidden partially by the kick panel, but it is a piece o cake to r&r. actually, i'm surprised you arent having light problems, the light wiring all goes through it, and when the switch fails often times so will your headlights. good luck
Sean
Franklin D. Roosevelt
68rs406 is offline
post #5 of 5 (permalink) Old Jun 18th, 03, 11:29 AM Thread Starter
Thanks guys..
I found a parts store and got the part without hassles. it's a pretty generic part and was used in several GM cars during that period. Funny you mention it, but I did have some wacky light problems. When I turn my headlights on, the temp/oil guage (aftermarket cheapos) peg all the way to the right. When the headlights are off, the guages work fine..so not sure, but most of the wiring looks like it was thrown together with electrical tape. I'm sure it could use an entire re-wire, but I'm not really sure how to go about that. Just got the car a week ago and have barely had a chance to look over it in detail.
rphtx is offline
