Tail/Brake Light Problem (Long) - Team Camaro Tech
post #1 of 3 (permalink) Old Dec 21st, 02, 01:57 PM Thread Starter
Problem isn't with the '68 but with our '56 Suburban.
Sockets use an 1157 bulb and heres the wiring set-up and the problem:
* have three wires. Blue is dedicated to drivers side, red to pass, yellow runs to drivers side socket and is jumped to both the door mounted tail light and pass side socket. There is a blue and a red wire coming out of the brake light activation switch, up to inside the dash (mate with turn signal wires?) and come back out so I'm assuming that this is why these wires are each dedicated to one side.
* drivers side works correctly, headlights lights on or off. Longer filament works tail lights, shorter works brake and turn signal.
* Door tail light works correctly.
* pass side/headlights off. Longer filament lights dimly when brake applied. Longer filament works turn signal when applied.
* pass side/headlights on. Longer filament lights dimly. Nothing when brakes applied. Longer filament blinks slower when signal applied.
Lower filament on pass side bulb never works.
I've removed the socket from the housing and worked the bulb both ways (contact to contact) and have the same problem either way.
Wires/connections are all fine.
Any thoughts??
Thanks!!!!!!
Desert 68 is offline
post #2 of 3 (permalink) Old Dec 21st, 02, 06:13 PM
Mike, 69's rule
zuma's Avatar
I know you have heard this a thousand times but, Did you check your grounds? Sounds like your circuts will crossover (lights dim) when there not supposed to be on at all is a indication of a circut looking for a ground. Try checking all your grounds, should have one in the rear on the body and also under the dash and hood. just guessing. good luck Mike
zuma is offline
post #3 of 3 (permalink) Old Dec 22nd, 02, 07:02 AM
With all the bulbs installed, take a piece of jumper wire. Touch one end to the passenger side bulb base. Right where it meets the glass. Touch the other end of the jumper to a good ground. Have someone step on the brakes. See if the bulb filament "reverses" and the proper one lites up.
John_Muha is offline
