Dash Clock - Team Camaro Tech
post #1 of 2 (permalink) Old Dec 28th, 02, 07:22 AM Thread Starter
Does anyone know of a good place to send a clock out to get repaired? Also to test it could'nt I hook it up directly to a 12 volt power source (i.e. battery) to see it is the clock or a bad wire?
winmon is offline
post #2 of 2 (permalink) Old Dec 29th, 02, 06:29 AM
JohnZ's Avatar
Yes, you can connect it to 12 volts to test it - it's usually the points for the rewind mechanism that are corroded, or the mechanism is just gummed up from age. I've had good luck with The Clock Works ( www.clockwks.com ) - top-quality work, reasonable prices.
JohnZ
CRG
'69 Z28 Fathom Green
JohnZ is offline
