Fuse Block under dash - Team Camaro Tech
post #1 of 2 (permalink) Old Jan 31st, 03, 03:06 PM Thread Starter
I am redoing my wiring harness. I noticed the fuse block has some rust on the clips. Any ideas to clean the clips? Sandpaper, sprays, wire brush?
Edsz28 is offline
post #2 of 2 (permalink) Old Jan 31st, 03, 05:41 PM
Kevin
KevinW's Avatar
I used a glass beader to take rust off electrical connectors. Works great, doesn't harm plastic, but give the plastic a satin finish. If you want to keep the gloss look, mask the plastic. The glass beader will also take the painted lettering off, so you have to mask those too. But don't put the tape right on the words. Use a thin strip of paper wide enough to cover the letters with some tape exposed on the edges.
Luck, Kevin
KevinW is online now
