Lights flicker - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 26th, 01, 03:10 PM Thread Starter
Hi guys....The interior and exterior lights have a slight flicker to them that seems to correspond to engine RPMs. I have a stock 68 that runs nice. Can you steer me in the right direction. Is it a voltage reg. or alt. that needs attention?
thanks,
Sean
gldn slmbr is offline
post #2 of 3 (permalink) Old Mar 27th, 01, 05:49 AM
Cool
Tighten alternator belt. Clean batttery posts and cable clamps along with the ground conn on engine. Make sure ground straps are from eng block to firewall, i.e. valve cover bolts to bolts on firewall.
Take a voltmeter and measure charging voltage at battery. Should be 13.8-14.8 volts. Turn-on headlights, should drop to 13(?) volts. Rev up eng to 1200 RPM, should come back up to 14 volts. Nothing wrong, just the ext regulator is not doing its job 100%.
You can choose from two options:
1. If you like to keep the stock & original look, then buy an aftermarket "electronic" regulator and replace the regulator.
2. Or more costly, replace the regulator and alternator with a one-wire alternator.
post #3 of 3 (permalink) Old Mar 27th, 01, 07:24 AM Thread Starter
Everett...Thanks for the reply! I will work on it this evening. After I read your advice I went out and found a ground strap dangling from the firewall so I will attach that and do the other checks you suggested as well.
Thanks again,
Sean
stock 68 327/PG convertible
