voltage regulator help - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 23rd, 04, 06:49 AM Thread Starter
69 camaro 205 amp alt one red wire with fuseable link one brown wire one white wire one blue wire. wich of theese do i jump to bypass alternator light so it dont cpome on on the dash pannel.? is it possiable to remove this regulator all together i have no horn and would like to clean up as much as i can for that simple hidden look. and if i can remove it is there any thing i have to rewire as there is a f/l on the big red wire.? thanks
69copo540 is offline
post #2 of 6 (permalink) Old Dec 23rd, 04, 07:26 AM
a search would have found this https://www.camaros.net/forum/ultimat...82.html#000000 from just last month.
post #3 of 6 (permalink) Old Dec 23rd, 04, 08:12 AM Thread Starter
i only need one 4 gauge wire to my battery terminal from my alt. what do i do with the wires at regulator id like to eliminate the reg alltogether there is one fat orange with a fuseable link one small blue one small white and one small brown ?
post #4 of 6 (permalink) Old Dec 23rd, 04, 08:25 AM
Do you really have a 205 amp alternator?
While you might only need a 4 gauge wire to the battery what kind of wiring upgrades have you done to the rest of the harness to distribute power to the loads you have that necessitated the 205A alternator.
There is a red 10 gauge wire that runs from the battery to one terminal of the horn relay which supplies all the power to everything in the car except the starter. This wire is also the charging wire from the alternator to the battery in a stock setup. That wire is way undersized if you have added that much current to the car. That redwire is connected to the to the alternator output wire in the stock setup, and from that connection to the fuse panel inside the car. None of these wires is larger that 10 gauge and for the most part are only good for the stock equipment originally installed in the car. If you have a huge stereo, or electric fans these have to be wired with a completely new set of circuits with wiring sized appropriately.
Heres and article on removing the Voltage Regulator:
https://www.camaros.net/techref/ftecref14.html
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #5 of 6 (permalink) Old Dec 23rd, 04, 08:37 AM Thread Starter
yes its custom made and im bogged down with relays and for a start i need to remove and rewire some things to handle the load .
post #6 of 6 (permalink) Old Dec 23rd, 04, 02:40 PM
Fot a stock harness, a bypass connector is sold to bypass the regulator, it plugs in in it's place.
I think you might need to do more than that, tho, to clean everything up.
maybe some details on your setup would help? Is it a one wire or 3 wire alternator (assuming internally regulated)? What kind of "extra's" and how are they connected now. Does your charging system work now?
