backup lite? - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 26th, 03, 09:08 PM Thread Starter
Big daddy
I want to install a back up swtich on my hurst comp+,what I want to know is there a harness that goes with the switch.
67ssclone 327 4spd 410
carhodge is offline
post #2 of 4 (permalink) Old Jan 31st, 03, 09:26 PM
From what I have read, Factory Fit can make you a harness to use with the Hurst backup switch if that is what you have. I'm currently working on the same thing as part of my M20 rebuild project.
It is suppose to be a beautiful weekend here in Oklahoma and my car is in pieces.
Donald
68 Camaro convertible (L30/M20, L48, or neither?)
MytMini is offline
post #3 of 4 (permalink) Old Jan 31st, 03, 11:56 PM
It may be more expensive, but you could rig it up stock with the reverse switch mounted on the tranny. Here is an old post: https://www.camaros.net/forum/Forum10/HTML/000863.html
bonecrusher67conv is offline
post #4 of 4 (permalink) Old Feb 1st, 03, 08:37 PM
ricks camaros has a switch and bracket in the catalog for this application. if you had an auto in car before you can run two wires down there and hook to new switch, ditto if you had 3 or 4 speed before.
Oramac68 is offline
