Starter solenoid wire? - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 28th, 03, 11:25 AM Thread Starter
I am wondering if anyone has a diagram or knowledge of the route of the starter solenoid wire (the smaller red wire in the 3 o'clock position on the solenoid). My car is a 91 RS w/ 3.1 Auto
The starter is new and works fine when the terminals are jumped but does nothing with the key in start position. Is there a fuse or fusible link on this wire (or a relay)? I cleaned the connections at the starter, the battery and the block behind the Passenger side headlight and have had no luck. Thanks for any help.
jack91rsv6 is offline
post #2 of 5 (permalink) Old Jan 28th, 03, 01:31 PM
maybe your ignition switch is toast, or fell out of adjustment. or the neutral safety switch could be bad or out of adjustment. i think the neutral safety switch is mounted on the shifter- take off the console cover and look for a purple wire, if they use the same coloring as the older cars do. check for power with a test light while you move the key around, and with the shifter in different positions.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see dirty pics here of a car that gets driven http://community.webshots.com/user/novaderrik
novaderrik is offline
post #3 of 5 (permalink) Old Jan 28th, 03, 06:50 PM
If your ignition key has the little magnet on it that may be causing the problem. They go bad after a while. I'm not sure if it keeps it from turning over or starting.
'69 RS Camaro
355 5-speed 4.11
[This message has been edited by 1 2RUN (edited 01-28-2003).]
1 2RUN is offline
post #4 of 5 (permalink) Old Jan 29th, 03, 07:18 AM
ZZ_430's Avatar
Check for broken "Pass Key" wires at ignition lock cylinder.
Don~ ZZ430DropTop
~~~~and~~~~
70 RS
ZZ_430 is offline
post #5 of 5 (permalink) Old Jan 29th, 03, 09:08 AM Thread Starter
Thanks for the suggestions. Heres one more question. The car starts and runs when jumping terminals on the solenoid with the key on. Could that eliminate the possibility of a pass key problem or not? I am not very familiar with the wiring in the ignition with respect to pass key. I have two original keys of which both yield the same results. Im 99% sure the pass keys are ok. This starting problem was intermittent at first. I had on and off starting problems three times before whatever finally took a dump and prevented starting all together. Could this possibly be the starter relay burning out?
I noticed you guys who responded have older rides which may not have starter relays- I know they used ballast resistors to control startup juice in the 50's and maybe the 60's? Anyway, thanks for all the help you can offer.
