ignition problems - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 19th, 04, 10:33 AM Thread Starter
i have a 69 camaro, 350. i replaced the battery and the positive battery cable. when i did this now the gen. and oil light in the dash comes on when there is no key in the car. then i started it up and it would not turn off, so i unhooked the battery and it still ran, so i disconnected the coil and it shut off. i am lost on what the problem is.
clemon505 is offline
post #2 of 5 (permalink) Old Mar 19th, 04, 10:40 AM
Robert
Check and make sure the small yellow wire that goes to the starter is not touching the positive cable that goes to the battery. A lot of times this wire is left unconnected and dangling.
Robert
TC member #18
rojo is offline
post #3 of 5 (permalink) Old Mar 19th, 04, 11:06 AM
Steven
Rojo is correct... To be clear, he is not saying to leave the yellow disconnected ... The yellow energizes the ignition system during "cranking" . Make sure yellow and purple are isolated from the large stud that the battery cable connects to...
sdtsdt is offline
post #4 of 5 (permalink) Old Mar 19th, 04, 12:45 PM Thread Starter
thanks that took care of it.
post #5 of 5 (permalink) Old Mar 19th, 04, 02:47 PM
Robert
And by the way since you have a '69 it is mandatory that you visit often and make many post. In other words welcome to the site. [img]graemlins/waving.gif[/img]
Robert
TC member #18
rojo is offline
