Hood Light - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 21st, 04, 09:40 AM Thread Starter
On a cowl hood were should i install the light? Thanks
Mike , Mountain Green,67R/S , 350 ,T400 , A/C
mike shields is offline
post #2 of 5 (permalink) Old Mar 21st, 04, 01:00 PM Thread Starter
Well maybe i should say under the hood,engin bay. thanks
post #3 of 5 (permalink) Old Mar 21st, 04, 01:45 PM
Goes along the crossmember nearest the cowl just to the left of the brake booster usually.
and
Brian Lewis is offline
post #4 of 5 (permalink) Old Mar 21st, 04, 02:29 PM
1.70 inches rearward and .4" outboard of the rear inner insulation fastner under the scoop. Use the fastner on the master cylinder side if it's a small block, and the one on the passenger side if it's a big block or 6 cylinder (not that your going to find a 6 cylinder with a ZL2 hood). Basically it goes on the same side as the oil dip stick.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #5 of 5 (permalink) Old Mar 22nd, 04, 01:39 AM Thread Starter
Thanks alot Brian and Mark.
