Quality of used Wiring Harness - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 29th, 02, 02:48 AM Thread Starter
I made contact with someone that wants to sell a complete (but used) wiring harness assembly for a 68 Camaro (fuse box and all). I haven't seen it and have no way of verifying its condition other than his word that its good. He only wants $125 for it. Would you take a chance on something like this?
garfield is offline
post #2 of 3 (permalink) Old Nov 29th, 02, 03:51 AM
Gary
In a word, no. However, if that is the amount that you can afford, then yes. Besure to check all the connections and the wires themselves carefully before the installation. I would prefer to wait and get a new harness.
Gary Dorion is offline
post #3 of 3 (permalink) Old Nov 29th, 02, 04:05 AM
The problem with 30 year old harnesses is that the insulation gets brittle. Also, I haven't seen too many that weren't hacked up by 30 years of stereo installs, and other aftermarket goodies. Another common problem is the fuse tabs. They weren't heavily plated and almost all loose their spring tension and corrode.
If you must rewire, I'd strongly consider the aftermarket. There are at least three major suppliers of harneses. Some are very close to factory. Others bare little resemblance to factory, but are better in some ways because of extra circuits. If you buy aftermarket, keep the old harness around. You may end up having to use some of the connectors on it. Also, the old harness will serve as a good template when installing the new one.
No matter which way you go. Be sure to seal up the connections at the fuse panel and other places where water and road grime can hide and degrade the connections. I plan on doing a solvent wipe down on mine and reinstalling until I get the cash to replace it.
-dnult
dnult is offline
