Tic Toc Tach wiring - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 28th, 02, 08:41 PM Thread Starter
Just acquired a tic tock tach for 68 camaro. No wiring harness received. Need the wiring code for the circuit board on the back. Assume it is a 12 pin connector, 6 top, 6 bottom. If you visualize the pins as 1 thru 6 top, and 1 thru 6 bottom, with 1 being the outside of the car and 6 being closest to the center of the car. What are the wiring colors for the positions? I can deduce that on the bottom, 1 and 2 are for the low fuel, 3 is the left turn, 4 is the brake lite, 5 is left blank and 6 is the right turn. On the top, 1 thru 4 are solid and must be the background lighting, I am guessing 5 is the tach and have no idea of the wire color and the 6 position is blank.
Also there is a pin connector at about the 4 o'clock positon on the tack side, again I assume this is the clock hookup????Wire color???
Thanks for the help.
f105thud is offline
post #2 of 5 (permalink) Old Dec 29th, 02, 06:12 PM
I put these two pages of the connections up; Iíll scan and post the rest as soon as I can.
The connectorís picture is large and takes a while to load. If I made it smaller it would be unreadable. http://gvtc.com/~rlaa/Electrical/
Geezer
Geezer is offline
post #3 of 5 (permalink) Old Dec 30th, 02, 08:30 PM Thread Starter
That is the exact information that I am looking for. On the JPEG, it has the console plug and wiring info, but the dash wiring plug is shown but has no wiring information. Can you send or was it cut off in the pic? Would like to have the same info for the dash wiring plug, wire colors to the numbered holes. Thanks.....thud
f105thud is offline
post #4 of 5 (permalink) Old Dec 31st, 02, 02:41 PM
OK. I scanned a couple more pages and cleaned up the connectorís diagram. Iíll clean up the console diagram and more when I have a chance.
Geezer
[This message has been edited by Geezer (edited 12-31-2002).]
Geezer is offline
post #5 of 5 (permalink) Old Sep 21st, 04, 05:54 PM
kris
Send a message via AIM to kristofer
could i please have that information as well...i know this is an old post but i need some help with my TTT
email to [email protected]
1968 CamaroCorvette Bronze 396 TKO-
1978 Camaro Type LT 99% original
2005 FLSTFI 15th anniversary Fatboy Softail.
kristofer is offline
