'67 voltage regulator - Team Camaro Tech
post #1 of 2 (permalink) Old May 21st, 04, 04:57 PM Thread Starter
My voltage regulator has bombed twice now within the last 6 months. When I checked it out you could see how there was a tit on the point surface causing it to charge full bore all the time. What would make it do this. If memory serves with the old ignition points system it indicated a bad condenser. Thanks for any input guys. [img]graemlins/waving.gif[/img]
<a href="http://members.cardomain.com/tucson" target="_blank">http://members.cardomain.com/tucson</a>
Tucson '67 RS is offline
post #2 of 2 (permalink) Old May 24th, 04, 01:22 AM
I believe you to be partially right. The 'tit' on the point contact also serves/ed as an indicator if the condensor was too small or too large, depending on which contact the 'tit' developed.
You should find an older, ie, '74 or earlier, Motors manual and follow the instructions for adjusting the regulator. You'll also need a reg thermometer to help set it up. Or maybe take the reg to Advance and let them check it out for free, or buy an electronic one in the old case.
