69 Camaro Fuel Gage problem - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 6th, 04, 06:53 AM Thread Starter
Red face
Can someone help, I installed new tank, used old sending unit, (worked fine before I change tanks)Now guage reads at 3 o"clock. I have check fuse, all connections including ground. Can't seem to make it go back to normal position. Camaro Muscle
ambush904 is offline
post #2 of 5 (permalink) Old Sep 6th, 04, 02:48 PM
If it worked before and you are SURE that it is wired correctly, check the float in the tank
Good luck
badboy is offline
post #3 of 5 (permalink) Old Sep 6th, 04, 04:47 PM Thread Starter
Thanks,I will pull the tank off tomorrow and see what it looks like.
post #4 of 5 (permalink) Old Sep 6th, 04, 05:25 PM
Gauge pinned high indicates open circuit. Make sure you have the ground wire from the sender reinstalled on the trunk stiffener infront of the gas tank, above the muffler.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #5 of 5 (permalink) Old Sep 9th, 04, 05:31 PM Thread Starter
Thanks MArk, I took the sending unit out, and the groung was barely arrached. I redrilled the ground and tha fix it.
