69 Starts sometimes and but not always - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 3rd, 03, 02:52 PM Thread Starter
Billy
Unhappy
Hey guys help me out on this one; I have a 69 camaro that I had put and external switch on so I can adjust the valves by pushing a button under the hood. This switch always works, but the key has started giving me problems it will work sometimes but not others usually when the car is hot. If the key does not work, all I have to do is push the button under the hood so the starter will click and then the key will work. I did check the neutral safety switch and it was not the problem but I have no idea what it would be except the ignition switch. Any ideas on this?
'68 with a 385 and dart pro1 heads, Irson Solid roller, air-gap intake, th350 w/3000 stall and 3.73 gears. 7.26 @ 94.45 in the Eight .<br />'69 SS with a 427 with edelbrock oval alum heads, comp cam solid roller, Victor Jr intake, 750 street dominator carb with Turbo 350 3500 stall and 4.11 gears 10:[email protected]
68and69ss is offline
post #2 of 3 (permalink) Old Jun 3rd, 03, 03:26 PM
Very common problem. You have a lot of resistance in your starter wiring. The purple wire does not have enough volts to engauge the solenoid when it gets hot. Your pushbutton works because it bypasses the resistance in the regular factory starter circuit. You can trace down the circuit and find the source of the high resistance or just add a Ford starter solenoid to the circuit and be done with it. Do a search on this, it has been discussed many times.
-Mark.
stingr69 is offline
post #3 of 3 (permalink) Old Jun 3rd, 03, 05:07 PM Thread Starter
Billy
Angry
Thanks Stingr69
I have the car up on stands now and I will trace the wires down and change it to see if that will work. It really S__Ks when your all straped in and you have to get out to use the button under the hood to fire it off.
