converting 3 wire alt. to 1 wire alt. - Team Camaro Tech
post #1 of 6 (permalink) Old May 19th, 17, 07:55 AM Thread Starter
Probationer
vince
what is the batt. power supply point wire for.
drdirtdog is offline
post #2 of 6 (permalink) Old May 19th, 17, 07:57 AM Thread Starter
Probationer
vince
Re: converting 3 wire alt. to 1 wire alt.
take that back what is the batt. power sample point
post #3 of 6 (permalink) Old May 19th, 17, 11:59 AM
Rufas
I hope this is in regard to the INTERNALLY REGULATED 3 wire alternators, as the externally regulated alternators also have a 3 wire connect. If the internally regulated alt, I do it the way GM does it, simple.
BATTERY cable to large BATT lug on back of alt
14 gauge jumper wire from BATt terminal on back of alt to side terminal number 2 (Please note, this is the way GM sires tham up, and, there is also a farm and industrial implement regulator for these alternators, those regulators do the same as the external jumper wire, but, INSIDE the alt, and are what the aftermarket builders use).
If you are not running a charge light, done, works
If you are running a charge light, simply connect the charge light to the number 1 terminal, with no other resistor/diode in place, done, light works as stock
dave ray is offline
post #4 of 6 (permalink) Old May 19th, 17, 12:58 PM
Chris
130fe's Avatar
Just curious, why are you converting from 3 to 1 wire?
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is online now
post #5 of 6 (permalink) Old May 20th, 17, 08:50 AM
Rufas
I can think of a few reasons.
dave ray is offline
post #6 of 6 (permalink) Old May 20th, 17, 09:56 AM
Chris
130fe's Avatar
Post Re: converting 3 wire alt. to 1 wire alt.
Not asking you, asking the OP Drdirtdog. Just curious if the OP is having alternator issues with his current setup or just changing it because someone recommended him to do it.
Chris
130fe is online now
