can i disable light sensor that turns on my headlights? - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 6th, 00, 01:33 PM Thread Starter
anyone know how to disable whatever turns on my headlights when the car thinks it's dark outside? 1999 Z28. i'm sure you guys must know what i'm talking about, it sucks to not be able to turn off my headlights when it's dark and the car's running.
camaro305hp is offline
post #2 of 8 (permalink) Old Oct 6th, 00, 04:13 PM
We just pull the fuse in the Lumina's we use at our Sheriff's office. Works for us and not much trouble to replace them when we want the lights back.
Black69 is offline
post #3 of 8 (permalink) Old Oct 9th, 00, 05:31 AM Thread Starter
it's a good idea, but the lumina fuse setup must be different. i've tried pulling all the fuses associated with the DRL's (daytime running lamps), but i always lose something i need (like brake lamps, tail lights, etc. don't want to get pulled over by you for no stop lamps!) any other ideas?
post #4 of 8 (permalink) Old Oct 9th, 00, 02:47 PM
Talking
just remove the emergency brake switch that controls the light on the dash. When you put the emergency brake on the lights should go out. So just remove the switch and you get the same results. You may be annoyed by the red light on the dash though but just pop it out too.
[This message has been edited by palvey (edited 10-10-2000).]
palvey is offline
post #5 of 8 (permalink) Old Oct 10th, 00, 06:32 PM
JC
Send a message via AIM to JC69RSZ28
I too have the auto lights on my 99 silverado, you are talking about the headlights themselves and not the DRL RIGHT? I tinted the windows of my cab and now the senors always thinks it is night out and turns on the lights, hate it, want to diable it?
1969 RS Z28 Black, white deluxe interior,
http://www.corvetteforum.net/c3/corvettj
JC69RSZ28 is offline
post #6 of 8 (permalink) Old Oct 11th, 00, 05:26 AM Thread Starter
as far as the 99 silverado, my friend has the same truck. there's a button called "dome override" that you can push 4 times, either before or after (i don't remember) you start the truck and it will disable the auto headlights. just play around with that button, you should be able to make it work. my camaro has no dome override button....
post #7 of 8 (permalink) Old Oct 14th, 00, 03:56 PM
We have a 2000 Z28 and all you have to do is pull the parking brake up 1 click before you start the car and no lights will come on unless you turn them on.
69 RS/SS 427 4.11's
2000 Z28 Navy Metallic LS1 6 Spd T-Tops
Spooky is offline
post #8 of 8 (permalink) Old Oct 16th, 00, 01:46 PM
From looking at your wiring diagram, I think all you need to do is unplug the ambient light sensor. Hope this helps, but it might require a little work to get to.
AUTODR is offline
