69 Tach and HEI - Team Camaro Tech
post #1 of 7 (permalink) Old Dec 6th, 02, 11:52 AM Thread Starter
Paul
My tach works fine until about 5000 RPM then it gets all squirly(technical term). I can tell that the engine is revving higher, but the tach just bounces around.....Any suggestions?
<A HREF="http://www.stratagaz.com/69LM1/1969LM1Convertible.htm" TARGET=_blank>My 69 LM1 Convertible
</A>
paulm is offline
post #2 of 7 (permalink) Old Dec 6th, 02, 12:10 PM
click's Avatar
probably that 'rare' ...388 block of yours Paul,
click
69RS 350/255 LM1, Balanced, TRW forged pistons, .30 over, TH-350 auto.,
Dover White,Blue Vinyl top, F&R spoilers,pdb, close ratio ps,am/fm,3.08 Posi., A/C, fold down rear seat
My RS www.brainerd.net/~knudsen/69RS
click is offline
post #3 of 7 (permalink) Old Dec 6th, 02, 12:32 PM Thread Starter
Paul
LOL click!!
The rare 388 block is in a crate, this is the new 383 motor....
</A>
paulm is offline
post #4 of 7 (permalink) Old Dec 6th, 02, 12:42 PM
DjD
DjD's Avatar
Maybe a little spark scatter causing the tach to act up?
...Dennis
"The '69, the '96 our local club"
and the "daily driver"
DjD is offline
post #5 of 7 (permalink) Old Dec 6th, 02, 01:40 PM Thread Starter
Paul
"Spark Scatter"?? I've never heard that term before.
</A>
paulm is offline
post #6 of 7 (permalink) Old Dec 6th, 02, 01:49 PM
He's referring to the secondary (high) voltage from the coil leaking into the primary side. If you're using an external coil take a points type condensor and hook the lead up to the positive side of the coil and ground the condensor housing. There are also tach filters available.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #7 of 7 (permalink) Old Dec 6th, 02, 02:59 PM Thread Starter
Paul
Thanks for the explanation.....I'm a little slow, but I eventually catch on!
I am running a large body HEI with the coil in the cap.
</A>
paulm is offline
