Turn Signals Move Gas Gauge - Team Camaro Tech
post #1 of 5 (permalink) Old Aug 15th, 00, 12:58 PM Thread Starter
mbrekke's Avatar
When I have a turn signal on, the gas gauge moves back and forth slightly and then eventually drops down to "empty". When the signal clicks off, the gauge returns to normal. Anybody experience a similar problem?
mbrekke is offline
post #2 of 5 (permalink) Old Aug 16th, 00, 06:46 AM
As always with the dash problems, check the grounds. Then check all connections.
68 RS, Ash Gold,pwr windows,Hounds tooth
CA420 is offline
post #3 of 5 (permalink) Old Aug 16th, 00, 07:12 AM Thread Starter
mbrekke's Avatar
I'll check it out. Hopefully it's something that will jump out and slap me in the face. Thanks for the input.
mbrekke is offline
post #4 of 5 (permalink) Old Aug 16th, 00, 04:30 PM
Carl
Yep, grounds. Check the upper-center screw on the dash pod. This is the ground connection for the pod and can easily cause problems.
Click here to see see my car and hear 5-speeds. http://www.geocities.com/casanoc
CarlC is offline
post #5 of 5 (permalink) Old Aug 17th, 00, 03:50 AM Thread Starter
mbrekke's Avatar
Thanks Carl. That will be my starting point.
mbrekke is offline
