Brake Light Fun - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 23rd, 00, 07:13 PM Thread Starter
Ken
I ha a '68 and when I press the Brake pedal my Dash Lights illuminate, but the brake lights don't. I am missing the rear side marker light socket and am wondering since the ground runs off that socket, if thats my problem, or is my problem under the dash.
CamFrk68 is offline
post #2 of 4 (permalink) Old Dec 24th, 00, 03:39 AM
Johnny
Smile
Check the center screw in your dash gauge carrier that is the ground for the dash & if it is loose or the stiff wire is missing it will go crazy nothing will work right.
johnny
johnnyr is offline
post #3 of 4 (permalink) Old Dec 24th, 00, 10:54 AM Thread Starter
Ken
Where about is the screw located?
CamFrk68 is offline
post #4 of 4 (permalink) Old Dec 24th, 00, 01:29 PM
There is a ground strap or formed wire that connects to the speedo housing and then connects to one of the screws for the high beam lamp. Then from the high beam lamp socket there is another ground strap that connects to the carrier screw above the high beam lamp. Or, just connect a ground wire directly from the speedo housing to the dash frame somewhere. Like where the direction flasher holding clip is attached to the dash below the ignition switch.
bonecrusher67conv is offline
