'69 Backup Lights - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 8th, 02, 02:30 PM Thread Starter
I heard that Hurst makes a backup light micro switch that works off your shifter. Does anyone know where I can find this complete switch assembly? And how does it work? I don't like the Neutral Safety Switch setup. Thanks!
[This message has been edited by redlines4us (edited 12-08-2002).]
redlines4us is offline
post #2 of 8 (permalink) Old Dec 8th, 02, 07:15 PM
John_Muha is offline
post #3 of 8 (permalink) Old Dec 8th, 02, 08:50 PM
I solved that problem by spending a little over two grand and putting a Tremec 5-speed in. It has a reverse light switch built into the tranny. You mean I could have just bought a switch?
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
post #4 of 8 (permalink) Old Dec 9th, 02, 05:58 AM
Lance
I installed one of these switches when I swapped out my turbo 350 for an M20. The switch mounts to the rear travel adjustment bolt on the shifer. When you shift into reverse the lever depresses the switch, closing the contacts, and turning on the lights.
I got mine at Rick's 1st Gen. Go here to their catalog on page 91. Part number is HCP-7.
http://131.103.206.224/catalog/81-105.pdf
Spitfire44 is offline
post #5 of 8 (permalink) Old Dec 9th, 02, 08:31 AM
The switch I have came from Rick's as well.
I used the rear plate from a spare aftermarket Hurst shifter on my factory Hurst shifter assy as the aftermarket plate is interchangeable with the factory piece and has the required shifter stop bolts to mount the switch.
-Mark.
stingr69 is offline
post #6 of 8 (permalink) Old Dec 9th, 02, 11:33 AM Thread Starter
Thanks for the help. I just ordered one from Ricks!!
post #7 of 8 (permalink) Old Dec 10th, 02, 10:06 PM
Donnie
Send a message via MSN to 69DZ302
I bought the same part as Spitfire44 and installed it the same way. The mounting of the part wasn't bad at all, and I ran the wires up through the console, under the dash to the column where I connected the wires. Works Great! Good Luck, Donnie...
1969 Z28, Fathom Green, DZ302, M20, 3:73
2000 Silverado Z71, white, 5.3, ext cab, 4dr
69DZ302 is offline
post #8 of 8 (permalink) Old Dec 11th, 02, 01:49 PM
What about the wiring for the backup switch? I have the plug that comes out under the wiper motor. Is there a wiring harness, or just build my own?
sudo1a67ss350 is offline
