is the battery toast? - Team Camaro Tech
post #1 of 6 (permalink) Old Jun 4th, 03, 02:17 PM Thread Starter
Ok so I've been havin problems starting the car, and I finally got hold of a voltmeter to check a few thigs out.
I didnt suspect the battery cuz its a fairly new red-top Optima. However, I decided to check it just cuz- it read 8.8 volts across the posts. Eek!
So I hooked a big-bad 50amp charger to it that my mechanic said would do the trick in about 30 minutes. Well after an HOUR it only read 11.5 volts...
Is the battery toast?
jonwell is offline
post #2 of 6 (permalink) Old Jun 4th, 03, 03:03 PM
Try putting it on a low amperage charger over night. Also, when you hook up the big bad charger, see if the terminal voltage exceeds 15-16 volts. The battery should read about 12.5 when fully charged (off charger). A charging battery should read about 14.
-dnult
dnult is offline
post #3 of 6 (permalink) Old Jun 4th, 03, 03:30 PM Thread Starter
rodger that will do...
reads at 14.7 volts on the charger, so thats kosher I guess.
is 2amps overnite low enough?
jonwell is offline
post #4 of 6 (permalink) Old Jun 4th, 03, 04:16 PM
1-2 amps overnight {8-12 hours} should be enough to recharge it.!
I used to work at Sears auto center,we tried to recharge batteries at aprox .75 to 1.5 amps per hour,as a slow charge is a lot less harmful to the plates in a battery,and if the cells are able to desulfate,this is the best way to do so,and it is a longer lasting charge,low and slow,kinda like cooking in a crock pot,LOL.
[img]graemlins/beers.gif[/img]
I sold my Camaro,hope the current owner drives it.
Email
I live near Albany,NY USA,
where are You?
cavemanmoron is offline
post #5 of 6 (permalink) Old Jun 4th, 03, 04:18 PM Thread Starter
haha, gotcha, thanks man.
jonwell is offline
post #6 of 6 (permalink) Old Jun 5th, 03, 04:53 PM Thread Starter
well nothin worked, so I took the old battery back for its FREE replacement, hehe.
Seems that the battery was toast after all, I slapped the new one in and it fired right up! I'm happy again! Thanks for the help.
Oh lol the guys at the parts store were amazed that I managed to kill a red top optima in 18 months... I just said "If there's a way something can be destroyed, I will do it."
jonwell is offline
